hydro-cable conversion
Discussion in 'HYBRID -> EG-EK / DC' started by PhyRe, Jun 27, 2008.
  1. PhyRe
    PhyRe Senior Member
    ct
    ok so i looked around in the ref section and all that did a lil yahoo search and im not happy with what im seeing so now im going to ask spesifically(sp?)
    i have a 93 hatch with a lsvtec that needs a new clutch/tranny
    story is i bought the car cheap had a funny clutch and then it had funny flywheel noises and then it doesnt start/drive. it just stalled and jerked to a stop. so i was thinking my cluch wasnt engaging/didengaging slipping/burning or something 5th gear would pop out while on the hiway. and grinds when going back in.
    long story short i have a s1 cable tranny and need to know what i need to make this work. i have just the tranny no axles no clutch no flywheel but i do have it all for the hydro tranny that is on the car now.
    cliff notes: have to use an s1 tranny in a hydro car and need info on parts to make it work
    edit: if anyone is interested in buying said tranny i have a b16 to go with it (see sig)
  2. BrutalB83
    Rochester Hills, MI
  3. PhyRe
    PhyRe Senior Member
    ct
    well thanks for the only one to help but i knew that much im more interested in the parts internally to make it work ie like what clutch ls or s1? what is the dif between 90-91 and 92-93? is the 92-93 hydro? can i use my same flywheel(if still good) are all b series axles the same? need help fast. i cant keep bummin rides and taking taxis
  4. BrutalB83
    Rochester Hills, MI
    It doesn't really matter. Just use the clutch and fly that go with the transmission...
  5. PhyRe
    PhyRe Senior Member
    ct
    so it does kinda matter?:shrug::nutkick: not to break your balls but any more insite would be nice and thanks
  6. BrutalB83
    Rochester Hills, MI
    What I mean is that clutches are interchangeable between B-series transmissions. Go look up some after-market clutches on E-Bay, the same clutch will work for a 99-00 Civic Si, a Del Sol VTEC, a GS-R, etc. If in doubt, just get a clutch that's listed to work with the specific transmission you're using, but they're pretty interchangeable (within the B-series of course, D/F/H-series clutches obviously won't work). You don't need to worry about the engine versus the transmission, you just need a B-series clutch.
    [Cartman] You're breaking my balls here man, you're breaking my balls...[/Cartman]
  7. PhyRe
    PhyRe Senior Member
    ct
    so to :deadhorse: real quick- the only dif is how the cluch is engaged/disengaged via a cable or hydro? not the inner workings
  8. BrutalB83
    Rochester Hills, MI
