Hydro Clutch Cable Tranny
Discussion in 'HYBRID -> EG-EK / DC' started by b16a91crxsi, Dec 29, 2002.
  1. b16a91crxsi
    b16a91crxsi Member
    SEATTLE
    Will a clutch off of a GSR Y80 "Hydro" Tranny work on a Y1 "Cable" Tranny?
    I know the diff between the Hydro / Cable as far as the way they engage, but not sure if the clutch itself makes a diff? :beer:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If you can find the part number for both,see if they are the same.
  3. EGLSHB
    EGLSHB Senior Member
    i am pretty sure they will not work, as the input shaft on the hydraulic and cable transmissions are different, you might be able to use the pressure plate off of the hydro, but the splined part on the clutch will not....
