Hydro flywheel with cable tranny?
Discussion in 'HYBRID -> ED-EF / DA' started by riceracerex, Feb 4, 2010.
Thread Status:
Not open for further replies.
  1. riceracerex
    riceracerex D-Series Ninja
    Pryor, Ok
    Rick Rolled Bitches!
    Well, now that I have your full attention, *unless your still thinking about boobs* I have a quick question... again.
    I am just about finished with my y8 build and the question came up for my D-Series.
    Can you use a y8 aftermarket flywheel or clutch setup on the si transmission from a 90' Crx Si? Z6 even? I know the newer D's are hydro and mine is a cable. I may end up with a eg, but who knows?
    Just a quick question and you will be greatly rewarded when answered lol. :D
  2. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    I know for sure that every D from 92 till 00 is interchangable, dunno about obd0 trannys though. Should be, as I don't see why not.
    BTW you should be banned for false advertising, I wanted some boobs
  3. 95b16coupe
    95b16coupe New Member
    ct
    i almost hit him with neg rep. dumbass
  4. RoughKnight
    Ottawa, Ont
    wow, if your stupid enough to believe the sarcasm, then please refrain from posting.
    thx
  5. 95b16coupe
    ct
    i wasn't calling you a dumbass. i was calling the OP a dumbass.
  6. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    count the splines on the trans and friction plate if they're the same it should work.. im pretty sure the engine-trans bolt pattern is the same..
  7. RoughKnight
    Ottawa, Ont
    oh
    well in that case, more boobs!!!
  8. eg6sir
    cant post that shit in here... this isnt the NWS forum
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yes it will work as long as your trans is 90-91...if its pre 89 the splines count is differant
  10. eg6sir
    umm, no.. this isnt the NWS forum.. i dont give a damn if everything is covered.. enough is showing that someone can get in trouble at work
  11. D16SiHatch
    D16SiHatch New Member
    awww sad face, my pitcher was removed. fair enough though, i suppose it's not work friendly content. that's my bad :(
  12. 90_EF_Hatch
    90_EF_Hatch Señor Member
    Dallas Texas
    I used the 87 d16a6 cable tranny on my 95 z6 motor? idk if that helps you though.
  13. riceracerex
    Pryor, Ok
    Thanks guys. Work sucks but I guess it could be offensive or distracting to some. My old lady thought it was hawt. lol
    I will try matching up the splines. I am planning on a fidanza flywheel and ACT Clutch for a d16y8 so you guys helped alot. thx
  14. RoughKnight
    Ottawa, Ont
    i've heard bad things about fidanza, just fyi
  15. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    Geez, you're kind of a ruh-tard aren't you? :search:
  16. riceracerex
    Pryor, Ok
    Do you have cancer in the brain baldy? Start a war.
  17. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    What exactly did you hear?
    <-Ran Fidanza 7lb in both my old 90 Accord and 88 Civic.
    To answer the original question, YES! The hydro clutch(92-00) is the same as the 90-91 CRX/Civic with difference I believe being the throwout bearing. 89 transmissions work too; they have the same spline count with the difference being clutch diameter. This means that if you switch to a 90-00 clutch/flywheel, an 89 transmission will work fine. 88s are the bastards(different spline count and diameter).
  18. riceracerex
    Pryor, Ok
    :thumbsup: Explained the best. That answered my question and I guess I will start ordering the setup for my 90' si Trans in the crx and if I end up goin with a newer eg then it should work also with the hydro trans from the y8. I thought fidanza was a good brand? What would you recommend? I don't mind hearing peoples opionions, except when I get called a ruh-tard. That's just retarded and btw, that word has parents all over the us wanting it removed from the dictionary for some odd reason. Sticks and stones parents, sticks and stones.
  19. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i explained the same thing above..lol but ive never had a problem with fidanza..ran one in my 95 civic..my friend ran one on his celica..my other friend ran them in all his cars..need i continue?
  20. riceracerex
    Pryor, Ok
    How many friends you got? continue, lol.
Thread Status:
