HYDRO TRANS INTO CRX
gettocrx
Member
Hey guys! Im getting ready to put a b16 into my CRiX and was wondering how do I make the vss on the crx work if Im going to be using a b16 hydro trans... since the crx vss reads off of a cable and the hydro trans is all electronic?? Do i run the DA trans gear sensor?? Yeah! I also know that I got to run the trans mount conversion kit from Hasport.. Thanks!
you need to either get a vss from a b series cable tranny or get a jdm gauge cluster and run a wire for the electronic speeedo, your best bet is to find vss of a 90-93 integra trans and stick with your cable speedo
Damn... I thought so! guess got to start searching ebay :mrgreen: ..........aight thanks!
i was runnin a b18 wit a cable tranny in my eg hatchy i am guess you can just drop a clable ls vss into the same hole on the b16 tranny and plug and go it workin fo rme :mrgreen:
