I am bored of ls in crx....thinking....vtec
Discussion in 'HYBRID -> ED-EF / DA' started by pappaj, Apr 5, 2009.
  1. pappaj
    pappaj New Member
    woodstock
    I've put about 5000 miles on my ls swap, I feel like something is missing... Like in the 6000 rpm and up range. I have been anti-vtec, but now it seems that is all i need. I just want opinions on this upgrade whether it is worth money/time. How people enjoy their vtec's.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I loved my B20/VTEC setups, but you can make pretty respectable power with a compression bump and non-VTEC cams. It's generally easier than a head swap. Examples- A B20 on Honda-Tech is making 164whp with all stock internals and Crower 404 cams. A B18 with Crower 404 (or 405) cams and good tuning made 175whp on here.
  3. pappaj
    pappaj New Member
    woodstock
    that is not bad at all. I am more concerned on the cost side of things. If it cost the same to get cams and increase compression as is does for ls/vtec materials. I don't mind the work. I would have to pull the head anyways to raise compression. That is good insperation and it would keep me non vtec, which I like. I would like to get close to 200 hp. I think that would be ideal for the rex. 175 i think would keep me content for a little while.
  4. Briansol
  5. pappaj
    pappaj New Member
    woodstock
    Thanks for that. Just what I needed, going to price up both and see.
  6. Ryma
    Ryma Member
    Or you could get a turbo and when you get bored of the power its making you can bump it up and get it retuned.
  7. pappaj
    pappaj New Member
    woodstock
    The thought of turbo may have crossed my mind. I don't have a couple grand to play with right now. I am looking to spend about 1000 or less on the next upgrade. 1000 is easier to explain to the woman. Maybe I should look into a homeade turbo.
  8. eg6sir
    my guess would you need better gearing and you wouldnt mind your LS .. slap a b16/GSR tranny on there and enjoy
  9. pappaj
    pappaj New Member
    woodstock
    I do alot of highway driving so I do like the ls tranny. It is not bad, it just needs a little more power. If I did not do much highway driving I would be all over a b16 tranny. I had a zc in the car before, not positive on the tranny that is in it. The rpm's were about 4500 at 120km/h. With the ls I'm about 3750 at 120km/h. I think it was just the si tranny. It was nice and peppy, but I like a longer pull, so what I need is MORE POWER.
  10. pappaj
    pappaj New Member
    woodstock
    It pulls like a demon from about 3500-5500 rpm's then it seems to lack top end. I'm sure a p n p would make a world of difference, but too much money. I could have probably all the parts for ls/vtec for the same price as a p n p. I have been pricing out turbo setups. They can be had for fairly cheap. I have to read more about engine management first. Maybe visit some local shops for prices on chipping/tuning. It looks like i can do a cheap turbo for under 1000 dollars, before tuning.
  11. pappaj
    pappaj New Member
    woodstock
    I just found a gsr head for 650 with everything included. I just emailed him about the ecu. It is most likely a newer head like late 90's.
  12. eg6sir
    b16 tranny w/ ls 5th gear for freeway driving.. done...
    even if you get a vtec head.. you'll need better gearing still.. ls tranny will drop you out of vtec when you shift
  13. pappaj
    pappaj New Member
    woodstock
    I don't think I'm ready for picking apart trannies. That does sound nice though. I'm more concerned on the difficulty of the ls/vtec being worth while.
  14. Ryma
    Ryma Member
    That's why I suggested a turbo setup, a hmt can be done for next to nothing, It dosent look like you want to much power, just a bit more omf.
  15. pappaj
    pappaj New Member
    woodstock
    That is just it. I would like to stay non-vtec and n/a. Then again I am cheap. I joined Homemadeturbo.com and have been reading a bit around there. Ryma do you have any links to cheap skate ls turbo builds. I have been and will continue to look for ls builds. My main worry is engine management I have no experience with that, but I have an interest to learn. This car is now my everyday driver now that my woman has license and has taken over the truck. I was thinking about slowly piecing together a turbo but I want to learn more about engine management to feel confident enough to go ahead with it. I would like to just chip my ecu and learn to tune from there. I wouldn't mind taking it to a shop for a tune but I like to be confident on all angles myself before commiting.
  16. Ryma
    Ryma Member
    Well if you can get a manifold, go get a turbo in a junk yard and have it rebuilt, then go to a exhaust shop and have the down pipe made, intercooler piping on ebay I hear works in a pinch.
    Shop around, check out prices.
  17. pappaj
    pappaj New Member
    woodstock
    That part I'm not worried about it is the engine management that i'm worried about. I will have to get those prices first. I have a couple shops in mind
  18. lilsicsol
    lilsicsol i lOve my Ef sedaN..
    brooklyn...
    x2^^^^^
