I can't stop! (wondering about my SS brake lines)
Capt. Orygun
Win the Day
so I bout my SS lines, I just got some Stop tech, they're SS hydraulic lines, you can't fuck that up
this is what I bought
StopTech Stainless Steel Brake Lines: buybrakes.com for the front and
StopTech Stainless Steel Brake Lines: buybrakes.com for the rears
the application guide says R32,R33,S14,300ZX-All for the front and 240SX 89-98 for the rears so I HAVE to have ordered the right shit (R33 front calipers and stock rear calipers). So a question for you who've done this
here's the caliper
and here's the front brake line
specifically here's the fitting
how does that mate to the caliper?
now the rear lines (which are much to short to go in the front) came with a fluid bolt and line
http://i27.photobucket.com/albums/c174/Silverchild79/fluidbolt.jpg
which look like a much better fit but after examining the OEM lines these are way to short to be the fronts.
can someone enlighten me? I would think after 6 years of working with these lines on aircraft there would be no curve balls left...
cant view the pics from here at work
i will take another look when i get home and get back to you
they sent me the wrong ones for my bosess tl. too and the fitting broke and they would not pay for the fix the just sent the right ones after i complained
DONT INSTALL until you talk to matt at stop tech
DONT INSTALL
thank for the doomsday warning formby, who should I say told me to call (IE your name dood)
anyways for anyone trying to help me here's some more pics
The calipers came from Ebay, the seller had great ranking and he said they were R33, they do look slightly different then the 300Z
Here's the back of the caliper, there is a screw in bolt that looks to retian a small metal tube which serves as a line
Here's the front line kit, The "bulkhead fittings" are on either side of the line rather then just one, I'm not exactly sure how that's supposed to adapt to the claiper, and I'm an Aerospace Hydraulic craftsman lol. Those 2ea metal fitting you see in the middle are solid and slide across the surface of the line, I'm guess those with the brass reatining clips hold the line in place?
looking inside the bulkheads on one side the the interior surface is Male/Male on one end
And Male/Female on the other
After a brake line inspection on my stock system the rear line kit looks like a perfect match, length, fittings, everything, although I'm still not sold on using a brass O ring for a fluid seal :huh:
So that's as good as I can explain it
Thanks in advance
im sure you'll be fine with the o-rings... thats what alot of calipers use. all my hondas and mirages had that same type of fitting on the front calipers. its called a banjo fitting.
tell them a friend was sent the wrong lines with his kit and you want to verify that you have the right ones.... dont give him my name... i never sent the other lines back because he would not fix the broken fitting.
but he did take his time and helped me to the fullest of his ability.
Sometimes it's no fun figuring stuff out
the guy who sold me the calipers forgot to include the assembly I would need to connect the lines too
yup it's the right lines
see the attached
fuck
I was just gonna say it looks like the seller cut the brake lines instead of unscrewing it, as that is a hard line, and there is no reason to replace it with a braided line...
Time to go line shopping...
you can go to most auto parts stores and get the hard lines with the fittings etc...
might need to cut and re-flare them to get the proper length etc but its easy enough
that would be my suggestion
just bring a brake line and a caliper with you to verify the right fitting sizes
between buybrakes.com and stop tech I learned some stuff
1. Those front lines are mis made, the second ends fittings shouldn't me opposite like they are
2. The stainless lines they make for their aftermarket calipers should be a perfect fit for my car and the R33 GTS calipers, without the steel lines
the guy at buybrakes.com has been super helpful, I'll keep you posted
UPDATE
The guys from buybrakes.com forwarded the pictures to stop-tech to confirm the lines were incorrectly assembled. Once they got the confirmation they arranged the return.
Now the correct lines are being shipped to me with a return postage included, they charged my card $7 for the difference in price between the kits. And it's taken care of
Larry & Dave at buybrakes.com really took care of this for me. All I had to do was say I was unhappy and they made it right, research and all. I can't say enough good shit about the experience
Next stop, Brembo Rotors and rebuilding the calipers :)
clears throat
stop-tech doesn't know anything about brake lines it seems.... they always send the wrong lines
