I Finally I Got My Civic...motor Is Coming Next
Discussion in 'HYBRID -> EG-EK / DC' started by 22crazy, Jan 18, 2003.
  1. 22crazy
    22crazy Senior Member
    whats up. i finally got my ride...96 ek civic hb, and now i want to get an ls. The thing is that ive been reading through the forums and i know that i need a b18b that came from a 1996+ car because of the obd2. What i wanted to no is when i go get my motor...how can i make sure that im getting a motor with obd2...i no it will be an LS because ill read b18b off the block...but how will i no its from a 96+? thanks.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    well any engine from a non vtec teg from 96-00 will have a obd2 b18b in it.
  3. SolReaver
    SolReaver Senior Member
    different style valve cover, this is the 96+ style
    the sensor on top of the intake manifold is seen in this pic, near the center. Only 96+ have those.
  4. 22crazy
    how do the 95 and below look like...what distingushing features should i look for?
  5. 22crazy
  6. SolReaver
  7. 22crazy
    i just noticed...there is a hose that runs from the center of the Intake mani. into the top center of the valve cover.
  8. StorminMatt
    StorminMatt Junior Member
    On a 1996+ B18B, the valve cover is flat over the cams (as you have seen). On 1994-1995 motors, the areas over the cams are kind of stepped, with higher areas alternating with lower areas. ZC motors have a similar type of valve cover.
  9. a2nboiracer7
    a2nboiracer7 Junior Member
    On the 96+ motors have the PCValve on the valve cover(the hose that goes to the mainfold) the 95 and below doesnt have the PCValve on top of the valve cover it is located on the intake manifold.
