phyregod
!!YTINASNI
Well, I finally got my stereo system installed in the phantom project.
Alpine CDA-9847 Head Unit
Alpine SPR-17LS 6.5" Component setup for the front
Alpine SPS-170A 6.5" 2 ways for the rear
Setup:
Front speakers mounted in stock locations
Front tweeters mounted in doors
Rear speakers mounted in custom made fiberglass pods in the rear
Crossover networks mounted under the passenger seat
12 gauge wire to the crossover networks
14 gauge to the door speakers
16 gauge to the tweeters
14 gauge to the rear speakers
10 gauge power straight from the battery (fused, of course)
10 gauge ground
The only factory wiring I used was the illumination and the ignition signal. Everything else was replaced. Sounds pretty good.. Although the HU has trouble pushing all of that with its stock power (50w/channel) I will probably have to add an amp before its all said and done. At a reasonable volume though, it sounds great.. when it starts getting unbearably loud it starts breaking up pretty bad. You can hear the speakers starving for power. The rear pods were pretty easy, although time consuming. I had to add a 7/8" spacer to the door speakers, as those type r woofers were really deep. I'm sporting 1/8th inch clearance for the windows, and about the same clearance for the factory speaker grill. Just barely got them in there, it was a TIGHT fit.
And Alpine's radio tuner still rules the world in recieving radio stations. They have always had the best.
Anyway, I got several pics and will be posting them, probably tonight.. And I've started the rear suspension install.. Should also be done tonight as long as it doesn't get too cold or bowling doesn't take too long.
Setup:
10 gauge ground
