I HATE post like these but....
Discussion in 'Wheels / Suspension / Tires / Brakes' started by ahedau, Feb 20, 2004.
  1. ahedau
    ahedau Senior Member
    Middle GA
    Okay...tax check is in and I have $600 left to play with on the car ('92 VX w/ a Z6). I'm entering my 2nd year of auto-x (DSP) and was very competitive locally last year. I'm going to branch out this year and do alot more events. If I do well in the SEDiv I'll try my luck in Topeka in September.
    Here's the question.... Should I keep saving and get a LSD (I like Kaaz) or go ahead and get Illuminas/coil-overs all-around?
    Current:
    OEM front shocks w/ Eibach sportline
    AGX w/ GC coil-overs on the back
    14mm rear sway w/ DIY lower tie bar
    e-bay upper tower bar
    10# 14" alloy wheels & Azenis 195/60/14's
    Hell, any suggestions are welcomed....
  2. E_SolSi
    get your shocks/coilovers finished all the way around the car
    and maybe get a thicker rear sway bar 14mm is kinda dinky
  3. ahedau
    Middle GA
    Thanks!!
    You're right, 14mm sway IS dinky but it's what I could afford at the time and it's better than what was there......nothing!
    Koni's have been recommended but no spring. I don't have a preference other than the ability to corner weight and adjust as conditions dictate. And Tein is WAY outside my budget!!
  4. driver1
    driver1 Senior Member
    neuspeed or eiobach would be my suggestion....as far as price goes i got my neuspeed race springs on ebay for 112 shipped
  5. haccord141
    haccord141 Senior Member
    So Cali
    If you are upgrading those...you should also get new bushings, by Energy Suspension.
  6. driver1
    ya a complete urethane suspension bushing it would be a real good improvement to thinka bout as well
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Bushings (at least new, if not poly), struts/springs or coilovers (that's for you to decide), upgrade to a good rear sway set up like the comptech, but definitely bushings, it is amazing the difference new ones will make over your old, tired ones.
