I have a question?
Discussion in 'Engine Building' started by ls vtec teg, Mar 5, 2010.
  1. ls vtec teg
    ls vtec teg New Member
    hey guys
    so the question
    what the problems if you put a 11:6 pistons with gsr/b16 ECU on a b18 non vtec ?
    I now It is a stupit question Lol but I want to now all the problems
    Thanks
  2. prpprimo
    prpprimo Hondaholic
    ABQ
    b16 1600cc b18 1800cc
    Most commonly a larger displacement will have larger pistons;)
    compression ratio is not entirely significant in this case.
    Neither is running a (gsr)vtec ECU on a non vtec motor.
  3. Magana559
    Magana559 The Warden
    fresno Ca
    detonation, piston meld down, main rod and bearings being chewed up, fling a rod, crack ringland, crack a sleeve, scratch up skirts and walls......in short dont to it, you will have major engine falilure.
    If you have money to build a engine you should have money to tune it.
  4. Magana559
    fresno Ca
    B16a/b and B18a/b both have 81mm bore and same sized pistons. stroke, rods,deck high, and crank is diffrent.
    also compression hight, piston dome, and pin hight all play factors in CR.
  5. ls vtec teg
  6. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Thats right....B16 is the Baby Stroke. But its a ferocious baby!!
  7. prpprimo
    prpprimo Hondaholic
    ABQ
    I agree, they are factors. Just not significant. If I understand his thread right, he is wanting to know why he cant run his b16/gsr ecu with a b18 motor.
    Where compression ratio is a factor/significant?
    I suppose unclear questions will get unclear answers. :rolleyes:
  8. CAFROG
    NOR-CAL
    Should you run a stock B series VTEC ECU on a high comp build? No
    Can you? Yes
  9. Magana559
    fresno Ca
    looks like he wants to run a 11.6:1 CR on a LS non vtec engine and run a P72 or P30 ecu.
  10. ls vtec teg
    yes :D but thanks for that all info
  11. ls vtec teg
    but i do not want to make
    i want to no the problems
  12. Magana559
    fresno Ca
    That will happen, just tune it.
