I have everything right??
CRseX84
so i have this z6 im putin into my 91 crx dx. im ussing a 90 SI tranny, i orderd a new Exedy clutch, and im getin the ecu converted from auto to 5spd. im getin a OBD 0 - OBD1 harness conversion... is that all i need for the swap??? i know i shuld replace things while i have it out but $$ is limited... i have a si motor in my dx right now that i blew up, so i already converted to MFPI... now i just g2 convert the VTEC!! but let me know if im missing anything? thanks lots guys
Tyler
as you said you need or should replace parts while its out those parts are:
timing belt
water pump
mounts (since its a basic bolt in)
check the axles
tune up, plugs, wires, cap, rotor, coil, igniter...
fuel filter
fuel injector cleaner etc.
all accessory belts, AC/Alternator/power steering if equipped
just to name a few.... hope it helped, other htan that.. what ECU are you using?the harness you buy should be OBD1 to 0 so you can use hte p28 to control the VTEC on the Z6....
