Hey guys i just finished a direct engine replacement in a 1992 Four dour civic. The car had been sitting for two months and i started it before the swap. Took a while to start it but it ran for about 30 seconds before CYL 2 Rod went through the oil pan and that was it. Well im now finished with the swap, i go to start it and i have no fuel. With Key on, Engine off i dont hear the fuel pump turn on. However, when i power the pump directly to the battery i can start the car, so i have everything BUT Fuel working. I've checked all the underhood and dash fuses, and all are fine. Are there any fuel fuses/relays or anything related to that sort anywhere else on the car. With Key on engine off, i checked for power with a test light at the fuel pump plug and i have nothing. Please help me guys!! i need it
BTW - I have a CEL when i jump the fuel pump directly to the battery, but im not sure how to check the code. Hope that gives a clue
