i have no idea
Discussion in 'Civic and CRX - EF' started by goldwar, Feb 11, 2008.
  1. goldwar
    goldwar New Member
    hey guy my car has been acting up lately and not starting
    it cranks but wont fire up. then you let it sit for 10 min it will fire right up
    only happens when the motor it warm and you shut it off then try to start it again.
    When it wont start it spits the code 16 at me (fuel injector) and in the considering that the car runs great when its running I assume my injectors work...
    Another question i had is where does the engine harness ground out on the dual point fuel injection system in a 90 crx dx? I checked the injector wiring and it looks fine so i'm lost. and i don't have a multimeter or i would check voltages.
  2. tunercrazed
    tunercrazed HS Official Hippie
    Tennessee
    sounds like your fuel pump, my 88 did the exact same thing, then I replaced the fuel pump, filter, and screen and now it works fine, your looking at about a $230 fix.
  3. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    mani ground
    Your engine harness grounds out just below your battery.
