I need a P14 for a 92 Prelude with all wheel steer
92PreludeawsH22a
I need a P14 ecu for a 1992 Honda Prelude Si with all wheel steer(aws) and a manual transmission. Help I can't find one anywhere!
Of course I have searched no one can tell me if the computer reads the aws feature. Not all Prelude Si's came with all wheel steer. A normal P14 Without aws will work but then I loose the most fun part of the car. I'm trying to find out the actual code that is on an aws steer computer to be sure. Do you know what it is?
4ws is controlled by a diffrent computer located in the trunk behind the rear seat on the drivers side
if you are getting the 4ws light there are some great write ups on honda-tech
That is true the computer for aws is integrated with the abs computer but my ecm/ecu is not communicating with it correctly which is why i need the stock p14 that reads the aws feature. I will look up the information on honda tech.thamk you for your help.
