I need a refresher course
Discussion in 'Civic and CRX - EF' started by 89civichbfuturekiller, Aug 20, 2009.
  1. 89civichbfuturekiller
    89civichbfuturekiller New Member
    Hey Let me just start out by sayin I am not new to hondas, last car was a 91 crx hf with a B16 and a J1 both J-spec sippin on the bottle. But I just bought an 89 civic hatch SI. I want to do a low budget worth while build, with CRAZY power. Where should I start and what do I need. Keep in mind if it will be worth while I would like to use my block D16A6 for the build.
  2. D16SiHatch
    D16SiHatch New Member
    you're not going to make "crazy power" on a low budget build. especially if the a6 is your platform to work with.
  3. BrutalB83
    Rochester Hills, MI
    How much power are we talking? If you've built Honda engines before then you should know that it's not exactly cheap to make big numbers on them...
  4. DESPAIN
    flower mound TX
    ust swap a gsr in there and cai;exst and call it a day,.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
  6. DESPAIN
    flower mound TX
    good'ol injen sure does li,ke the "D"
  7. efalex
    efalex New Member
    Danville NH
    lol ^ no problem with the "D"... d series that is
  8. eg6sir
    boost is your only option
  9. 78civic
    78civic Junior Member
    NW MS, Y'all
    What about a EF exhaust mani, small turbo and bigger injectors and have a little fun..?
    E
  10. wholesaleabc
    wholesaleabc Banned
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    HF not EF and i dont think the guy is coming back
