I need help deciding on engines!!
Discussion in 'HYBRID -> EG-EK / DC' started by Huffman4242, Oct 29, 2007.
  1. Huffman4242
    Huffman4242 New Member
    I really need help deciding which engine swap to do, the b18c GSR or the b18c5 type R engine. I know most of the differences with the Type R but is it and the transmission it comes with really worth the almost $2000 more for it? The car its going in is a 94 Honda Civic. Or would I be better off using the 2 grand and putting that money in the GSR and its tranny?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    kepp the extra 2 grand just get the gsr
  3. norcalgsr
    NorCal
    If you have the money to pay for the ITR engine buy the GSR swap and put the extra money into building that up.
  4. Huffman4242
    how much better is the GSR engine gonna be over the ITR if i go with it and put 2 grand in it?
  5. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Type R - 195 hp
    GSR - 175 hp
    Then you add i/h/e, performance chip for ecu, maybe cams. It won't take much. i/h/e alone could possibly equal the type r.
  6. SeVeNisOnE
    SeVeNisOnE Ken Korn Karn
    Dallas, Tx
    I would go GSR and put the extra 2K into bolt ons for it. You can get a header, air intake and intake manifold, larger throttle body and exhaust if you can source some used parts. With that you might make a bit more power than a Type R.....maybe. But hey If you got the money, rock the Type R for more wow factor. If you plan on leaving the internals stock hit up the Type R. Did my advice just flip?
  7. norcalgsr
    NorCal
    Might as well just swap the pistons and cams on the GSR engine, and then you would already have more power than the ITR for less money. Screw a 'performance chip' it will do nothing for you.
    A set of agressive cams, high comp. pistons, and a 2.5" header back exhaust should get you 20+ HP easy before tuning.
