I need HELP !!!! H22
bigmachine02
I have Honda accord 1992 and a H22A1 swap complet and is runing low RPM and a very big LOST OF POWER and no check engine
What ECU are you running? Is your firing order right? Getting enough fuel? Getting spark?
Did you bother checking anything before you posted, or did you just get on here and hope someone would give you the answers?
I have the p13 stock i have fuel going in I have spark and a check engine 23 juste get out knock sensor I check my connection on the ecu and is right i change my sensor end is still flash 23 ???
