i need help wit this swap please
Discussion in 'HYBRID -> EG-EK / DC' started by Gshine21, Feb 17, 2009.
  1. Gshine21
    Gshine21 New Member
    i have a obd1 single motor that i have to drop in my 0bd2 ek my queston is what will i need to make this swap successful or is it a straight drop
  2. haao13
    haao13 New Member
    PA
    you would have to convert to obd1
  3. dtob
    dtob New Member
    Just do some searching, it is pretty straight forward. Like haao13 said convert to obd1 but to be able to use your stock harness etc you'll need the following:
    OBD2 alternator
    Your obd2 injectors
    OBD2 dizzy
    OBD1 ECU for that engine with conversion harness
    I think that's it, I did an obd1 B16 swap in my bro's EK and I'm pretty sure that's all we swapped out on the engine then used the OBD1 PR3 ECU with Rywire harness.
