I need help with my build
Discussion in 'Engine Building' started by Vtek, Oct 31, 2011.
  1. Vtek
    Vtek New Member
    I have a full gsr motor but one problem..it burns oils
    Mostly at high Rpms it blows a lot of smoke
    Idk if it is the piston rings the head gasket or the valve ceils
    Should I just rebuild the b18c head or buy a b16 head?
  2. Vtek
    Vtek New Member
    Also I Have a h22a head for sale or trade and a h22 transmission it's LSD
  3. Dj211855
    Dj211855 New Member
    not really a problem, Just do a complete rebuild. Do a leak down test to be specific.
  4. 98EkSi
    98EkSi New Member
    Vtec motors are known to burn oil at high rpms, the PCV system is to small. But could be the rings or valve oil seals.
  5. Matts96HB
    Matts96HB . Moderator VIP
    is the smoke under acceleration or deceleration?
  6. Vtek
    Vtek New Member
    Acceleration
  7. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Most likely rings. Could also be a restricted pcv system but IMO the rings are worn. See if you can rent a leak down tester and see what it shows.
  8. GlassHeadlights
    Calgary, AB
    I've been told after 150 k miles the valve guides wear out on all B-series VTEC motors.
  9. 98EkSi
    98EkSi New Member
    Yep rings if it while accelerating. Oh and just stick with the GSR head you already have it so ne need to get a B16 head. I prefer B16 heads for LS Vtecs because they do flow just a bit better than the GSR but mostly because you dont have to wire in for the GSR mani. You have the GSR head already so just stick with that either head will get you the same end result after P&P so dont waste money buying a new head.
