i need help with my d16
Greencivic97
hey wus up im new in dis pg bt mmm two days ago i started to take apart my d16 because i had a blown headgasket i unbolt all the bolts tht i had to from the head n harness also and hoses too but when i try to lift the head the head wont come off any sugestions plz?
make sure that all of the bolts are removed and try harder
it usually requires some prying to come apart
Ok i got it thnks alot guys now to put it back together the hard thing n got me stoped from workin wut to put back the timing belt i just slide it off n when i tryed to put it back on i cant get it on any suggestions how to lose it or sumtin
loosen the tensionor under the motor mount on the block. you will need a 14mm socket and a ratchet.. make sure you go by the book to put it back in time and proper way to tighten the belt..
