I Need Help With My H22 Harness
Discussion in 'HYBRID -> EG-EK / DC' started by fray, Jan 21, 2003.
  1. fray
    fray Junior Member
    hey evryone , can someone help me out . im doing a h22a4 swap in my 95 civic but now i dont know what harness to use . do i modified my civic harness to fit the h22 or should i use the h22 harness into my civic or i use both harnesses to make one to fit my car. also what s the right way to wire an external ignition coil im using a distributor from a 92 accordand the external coil is stock from the h22a4.
    Thank you so much for your help
    Fray :worthy:
  2. paragus
    paragus Senior Member
    use your civic harness
  3. fray
    fray Junior Member
    thank you for your help :)
  4. paragus
    no problem mang, i have a write up that was given to me if ya want it just gimme your email
  5. fray
    fray Junior Member
