I need help with what type of turbo i should use and how much boost i should push on a stock block h
Discussion in 'Prelude' started by brenaan, Jan 27, 2017.
  1. brenaan
    brenaan New Member
    I need help with what type of turbo I should use and how much boost I should push on a stock block h22a1? I was thinking a hx35 would be a good one but I don't know for sure. It is a a 2000 civic so I don't have much room also.
  2. Briansol
    the hx35 is pretty big (physically) and depending on the manifold design might not fit.
    the h22 also has crappy FRM coated sleeves which means no forged pistons without sleeving the block.
    I would probably go with a smaller set up and run 6-8 pounds, someting like a t3/to4e 50 trim .63 a/r
    CAFROG and dilbeckskate like this.
