I need help?
Discussion in 'Civic and del Sol - EG and EK' started by BIGJOSEPH, Feb 5, 2008.
  1. BIGJOSEPH
    BIGJOSEPH Big Joseph
    G-town VA
    On a 96 civic coupe with a 2000 ls swap, i got a check engine light on because there is two harnesses for the o2 sensor and the header i got only has one 02 sensor hole, i need to know what would be the easiest thing to do was weld a 02 sensor nut and drill a hole in the header or can you hardwire it in. any help would be appreciated.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just tap a hole and put it in there
  3. BIGJOSEPH
    G-town VA
    can i just drill and tap it or do i need to weld one of those 02 sensor nuts on it, and the 02 sensor in it now is on the far passenger side pipe where does this one need to go.
  4. AHHVTEC
    Alabama
    your gona need to make a hole then weld on a nut so you can screw the 02 sensor in
  5. BIGJOSEPH
    G-town VA
    what pipe should i put it on.
  6. AHHVTEC
    Alabama
    if its the secondary 02 sensor just put it at the bottom in the single pipe
  7. BIGJOSEPH
    G-town VA
    idk if it is the secondary the one that is plugged in is in the far passenger side pipe.
  8. AHHVTEC
    Alabama
    what colors are the wires on the one that you have plugged in and what colors are the one thats not plugged in
  9. BIGJOSEPH
    G-town VA
    well i went by the parts store and they said for that motor there should be one behind the cat, what should i do.
  10. AHHVTEC
    Alabama
    you need to tell me this
    1 person likes this.
  11. BIGJOSEPH
    G-town VA
    there are two blacks a green and a white.
  12. AHHVTEC
    Alabama
    ok this is the one you have plugged up and working right ?
  13. BIGJOSEPH
    G-town VA
  14. AHHVTEC
    Alabama
    coo then just tap a hole at the bottom where all the pipes come together and make one pipe , and put it there it will be fine
  15. BIGJOSEPH
    G-town VA
    ok thanks for the help
  16. BIGJOSEPH
    G-town VA
    should i buy the oxygen sensor that is supposed to be behind the cat. and put it in the header
  17. AHHVTEC
    Alabama
    do you not even have the stock one ?, but yes if you dont have it buy a secondary 02 sensor and put it where i said and the cel will go away
  18. AHHVTEC
    Alabama
    just let me know if you need any more help :cool:
  19. BIGJOSEPH
    G-town VA
    no there is not one there but ok i will do.
  20. BIGJOSEPH
    G-town VA
    my header is a 4-2-1 header, so just put it in the pipe when it turns into one.,\
