i need some help weird problems
Discussion in 'Forced Induction' started by travis93eg, Oct 12, 2009.
  1. travis93eg
    travis93eg New Member
    so i have fully built and boosted d16 z6 i just swapped into my crx and everything worked great before i swapped it in but now its acting odd... i cant get past lke 3.5-4k rpms once i hit that it acts like im hitting the rev limiter or 2 step... any ideas?
  2. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    Sounds like limp mode
    getting any cels?
  3. 78civic
    78civic Junior Member
    NW MS, Y'all
    What was "working great"?
    The setup you took out? Or the z6 after you swapped it in?
    Waste gate adjusted wrong?
    Clogged cat?
    You didn't change/upgrade the fuel pump
    TPS gone bad?
    E
  4. Briansol
    yep, limp mode. most likely bad wiring somewhere, the wrong ecu, or mis-matched obd0/obd1 parts
  5. Matts96HB
    Matts96HB . Moderator VIP
    I believe he got this working, I talked to him yesterday and he had someone tuning it to get it through emissions.
