im swapping a gsr into this new crx,
but i have h22 injectors, would i do the same
remove the box and solder all the wires together?
they are jdm 93 injectors
thanks
then yes if you are using obd 1 injectors you just cut the plug off of the end of the injector resistor box and solder all 5 wires together and there you go.
