i need to identify a throttle body....
Discussion in 'HYBRID -> ED-EF / DA' started by b18vtecrx, Dec 9, 2003.
  1. b18vtecrx
    b18vtecrx Senior Member
    ok i got a TB and i cant figure out if its obd-1 or obd-0. so with that in mind there is only one black sensor on it and i think thats the TPS and no other sensor. now the guy i got it from said it came from a first gen b16 but he also told me it was obd-1. but i thought the MAP sensor was on the TB on obd-1. so with all that knowledge can anybody tell me what TB i have? i need to know if i have to extend the wires on my crx from the firewall for the MAP or not so please help me out thnx -mike
  2. b18vtecrx
    nobody can identify this for me? -mike
  3. brian11to1
    brian11to1 Senior Member
    I dont think Throttle Bodies are OBD dependent, in other words I dont think they are different. Maybe the TPS is different. On OBD-0 the TPS is the only sensor on the TB. As far as I know.
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    88-00 tps's are the same...88-95 civic tb's have an external map sensor, all b series TB's have a tps and a map sensor on them (correct me if im wrong).
    If you doing a swap in a 88-95 civic any TB will work..if it has a map sensor on top you can get a blocker thing to cover it up. If your car doesnt have an external MAp sensor get a TB with one.
  5. brian11to1
    on my integra the map sensor is on teh firewall... I corrected you cause you are wrong.
  6. b18vtecrx
    on my crx my MAP is on the firewall also. now im confused tho somebody told i would have to extend the wires on my MAP and on my TPS why would i have to extend them if the TPS is in the same place as my crx one? oh and where is the MAP on B series? is it somewhere on the motor? please let me know asap thnx -mike
  7. brian11to1
    90-93 integra (with b series) its on the firewall
  8. b18vtecrx
    what about 94+ tegs? -mike
  9. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    JDM B16a SirII obd1
    MaP on Firewall
    **sorry thought i was in eg forum ***
  10. 92civicb18b1
    on my 94 ls engine the map was on the TB
  11. habit
    habit Member
    You should have a dashpot diaphram on the TB if its a Non-obd. And like everyone else said if you have a Map sensor on the TB then you have obd-1.
  12. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    The MAP sensor on my B18C is on my intake manifold, right in the middle of the runners, I believe.
  13. 92civicb18b1
    o brian (leanmeanmarine) this was one of my dumber posts, just for the record.
  14. brian11to1
    Haa haa.... nice, keepin tally? Me too... I think I have to close to 1300 stupid posts... and non helping threads.... maybe I should be banned.
