I Need To Know How To Change Engine Mount
Discussion in 'General Tech and Maintenance' started by acid_acura, May 18, 2003.
  1. acid_acura
    acid_acura Junior Member
    Hi , can somebody tell me how to change my rear tranny mounted engine mount of my 96 integra rs. Thank you.
  2. chet
    chet Senior Member
    st petersburg, florida
    well...your question isn't exactly clear...
    to change the drivers side mount and passenger side mount you just need to support the weight of the motor.
    the rear mount is obviously more difficult...and requires a good bit of work. this includes taking the axles out, unbolting the other two mounts, and lifting the motor up.
  3. acid_acura
    Thank you , It's the rear one that I have to change...
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    There is a engine lift the mounts on the sides of your engine bay,you an maybe rent one,but yea it is a pain since you have to disconnect the majority of things on the backside of your motor to give you enough room to move the motor out of the way to clear the mount.You maybe able to swing it with the axles in,but taking them out would be easier.
