I Need To Lean Out My Stuff
Sinner
Member
I running way to rich and my fields controller can only do -30% which It is already at. Is there anyother way to lean out the motor?
Nick
yeah, what is your setup?
I'm assuing your are running large injectors on a vafc hack kinda setup.
what size injectors? whats your fuel pressure at?
holy shit batman!! 30% rich!~>?
was this proven with a wideband or a shitty stock O2 and an autometer gauge??
it sounds to me like you've got SERIOUS issues...
no. you read that wrong pills.
with the VAFC hack, you run a larger injector, but tune its fuel to like -30% from STOCK at low rpms, as it is a larger injector and needs to idle.
example:
rpm- vafc setting
500 -30%
1500 -28%
3000 -15%
5000- 0%
6000- 10%
8000 - 20%
something like that
its what the VAFC hack is.
basically, by altering the signal to -30% it effectively lowers the voltage sent to the computer.
read up on it.
thedropshop.tv has a write up
damn, -30% is huge correction, i think at the highest magnitude mine is -13% which is at 5,000 rpm on the low cam. maybe by using some resistors on the map signal you can change it, maybe a variable resistor.. or you could switch to a apex vafc, it will do up to 50%
this is why i got a hondata. 'nough said.
