I need to put a new engine in my 88 crx
Discussion in 'HYBRID -> ED-EF / DA' started by Zreisinger, Jun 26, 2009.
  1. Zreisinger
    Zreisinger New Member
    I am trying to do whatever takes the least amount of work. I would like something that doesn't need mods. I bought an 88 CRX and the head is shot, so I figured I would just replace the whole thing and was wondering if anyone here could tell me the easiest one to do. I do believe that is is just a regular CRX, not si. I don't know the stock motor size and wanted some help on a swap. I don't want any more power than is already there. I just want a stock CRX. Any help would be appreciated. This is my first Honda so I don't know much about them but I do have general knowledge of motors and cars. Thanks for the help and I look forward to hearing from all of you on this topic.
  2. 95b16coupe
    95b16coupe New Member
    ct
    if you want what is in there, then just buy a stock engine. there are import companies that sell engines. check online and find something local.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well find out if the crx is a si or hf first
  4. Zreisinger
    I know it isn't an Si. So I guess it has to be an HF. Also I don't know the engine code for it. I do know that I have been reading alot and the D16z6 seems to be very popular for these cars, but I don't want to have to buy a bunch of aftermarket parts for it. So if anyone knows what the stock motor is in this please let me know. And if you know where a good place to get one for cheap. I am not trying to put $1000 into it, its just a car to get me from point a to point b for now. Maybe I will do a bigger swap one day but now is not the time.
  5. AHHVTEC
    Alabama
    well it could be a dx also. im needing to know if it has mpfi or not
  6. DESPAIN
    flower mound TX
  7. Zreisinger
    I am going to get the car tomorrow. I do believe it is the lowest grade CRX that they made in 88. I'm sorry I don't know much about these, I was a DSM guy for a long time but I am getting out of that because parts are getting way too expensive. I will let you know as soon as I do. I do believe it is MPFI. But either way if it is DPFI what would be a direct swap and need no mods? if it is MPFI whats the best in your opinion? Like I said I don't want to have to move motor mounts and all that, I would like to pull my motor and bolt another one in directly, any ideas?
  8. Zreisinger
    I will have pics tomorrow, but until then here is the craigslist ad I am buying it from. He has 2 pics up, I don't know if you can tell anything by that but I'll put it here anyways, Any help will be greatly appreciated.
  9. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the listing says CRX Si - $700 (Charlotte) and it looks like Si to me (i think i can see the sunroof)
  10. jlicrx
    Colorado Springs
  11. Zreisinger
    As you can see someone pointed out the obvious to me, lol. It is an Si. SO that being that case just a few questions.
    If I get the ZC, will I need a new tranny with it or can I use the one that is in it?
    Do I need to do anymods to the wiring harness if I get the ZC?
    And also what else will fit easily without modding the Wiring harness or motor mounts?
  12. jlicrx
    Colorado Springs
    ZC bolts right in using your transmission, mounts, ECU, etc. - the most you would need to do is swap your engine wiring harness onto the ZC - the SOHC ZC is essentially the same as the D16A6 that came in the Si, just has a little more horsepower - for a little more money you could get a DOHC ZC, which also bolts right in like the SOHC ZC - you would need to make a minor wiring change at the distributor when using the Si engine harness on the DOHC ZC
    you would need to use the 88 Si flywheel and clutch with the 88 transmission
  13. Zreisinger
    Do you know anywhere to get the stock D16a6 motor? Also have been hearing alot about the B16 motor. Will that fit with the tanny I have and the wiring harness I have?
  14. 95b16coupe
    ct
    stay away from that car. it has bad news written all over it. if you have $1500 to spend, find something else. there are other options out there.
  15. Zreisinger
    Why do you say this is bad news? I have already seen it and started it, it sounds fine. No knocking or anything. If you could let me know why this is a bad car?
  16. 95b16coupe
    ct
  17. AHHVTEC
    Alabama
  18. phyregod
    phyregod !!YTINASNI
    Central Texas
    Where are you located? I have a ZC, full swap, everything you need for sale.
  19. Zreisinger
    I am in Charlotte, NC. How much do you want for the swap? And you know FOR SURE this will bolt directly into my car with no mods?
  20. phyregod
    phyregod !!YTINASNI
    Central Texas
    Bah, I'm in Texas. Wouldn't be worth shipping it.
