i need vss pictures
Discussion in 'ECU's, Electronics, and Tuning' started by Dark91zc, Jun 24, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    does any one have pics for a 92-95 civic vss and 96-00 civic vss and 94-00 teggy vss thanks
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    i think they're all the same.
  3. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    wouldn't it be different for the B and D series trans?
  4. 92civicb18b1
    IIRC they're the same for the hydro transes.
    I could be wrong though.
  5. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    B and D series VSS are different....and If im not mistaken, the plug on the OBD1 and and 2 engine's are different.,....
    Heres a pic of the vss for ya....
    It was posted here not too long ago and i saved it..
    cLiCky BeaTcH!
  6. pissedoffsol
    plug on obd1 and 2 are different
    a d won't fit int a b tranny, and vice versa, but the plug is the same (for the obd anyway)
    obd0 are entirely different- use a different plug, output a different pulse width, and will not work with obd1/2 ecus. the converse is also true- you cannot run aon obd0 ecu with an obd1/2 vss.
  7. Dark91zc
    Corona,CA
    the car is already obd-1 :) and i had 2 get a 96-00 teggy vss and use a 92-95 gear and shaft with the 96-00 vss electronics
  8. Dark91zc
    Corona,CA
    the pic you have is the vss i already have :) i need to get pics of the teggy vss when i am done:)
  9. Estorvito
    Orlando FL
    WHat do you need to know about these?
    I have a 96 gsr, 95ls, and a 90civic speed sensors....
