I Need Your Opinon on A Frankenstein Motor ???
Discussion in 'Civic and del Sol - EG and EK' started by SunShine00, Jul 12, 2007.
  1. SunShine00
    SunShine00 Eager Student
    its a B20 block with a sir(b16) head and trany
    I was wondering what the setup would be worth ?
    and if I should jus avoid it because i heard that you can run into alot of problems with it .
    and some of the pro's and con's :confused:
    I know it puts out about 175whp and 150wtourque
    anyone framiliar with these type motors ?
  2. badasscrx
    badasscrx New Member
    Casper. Wy
    the motor comes for a crv and pros and cons also depend on what your planning on doing with it
  3. SunShine00
    i wanna make 300 to the wheels, and right now i have the choice of a b18c5 type R or the crv block b16 head, with b16 trany , not sure which is better but i think it will be cheaper with the crv ?
  4. badasscrx
    Casper. Wy
    yes b20 is cheaper you could put all that togather and then get exhuast, then turbo then some sort of fuel mangement system
  5. SunShine00
    but can you run a turbo on a b18 type R, on stock internals ?
  6. badasscrx
    Casper. Wy
    yeah only 1 psi tho so there no point
  7. SunShine00
    even on a usdm model, there compression is like 10: 5 i thought ?
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Wow, what wonderful misinformation...
    You can turbo a B20/VTEC without any problems.
    As far as reliability- if you take your time building it PROPERLY (just like any other engine) and don't cut corners, your B20/VTEC can be just as dependable as any other engine that you put together. Mine lasted for 45k miles of HARD driving and only let go because I did something stupid with it. Even then, the main bearings came out looking like new.
  9. SunShine00
    thanks , good to know,
    but i was wondering about the b18c5 type R though, can you run boost on that engine on with stock internals?, or is there a bunch of work needed to be done to the motor in order to run a turbo?, and if so what does need to be done ?
    oh and thanks for the reply by the way ;)
  10. phunky.buddha
    Yes, you can- but your tuning window is much smaller because of the higher compression. If you're a good tuner, you don't need to go inside. Over 400whp has been made on the B18C5 under boost with no internal modifications- but again, that's with REALLY good tuning.
  11. SunShine00
    really, thats so interesting , because ive heard the exact opposite from so many people, thats jus goes to show that a great tuner can make a Huge difference
  12. phunky.buddha
    :shrug:
    I've watched it happen.
  13. badasscrx
    Casper. Wy
    i dont beleive it eitherbecause ive heard the stock rods cant hold past 14psi with 9.5 c/r
  14. phunky.buddha
    Lots of people "hear" lots of things...
  15. hatchbros 93
    hatchbros 93 Junior Member
    Unless you already have the type R motor, id just boost an LS. You dont want the b16 tranny if your gonna boost, the LS tranny is ideal for boost, plus with the price of a type R motor, you can build an LS motor up pretty decent.
  16. SunShine00
    yea , i dont know about those ls/vtec motors, i think id rather build a gsr motor for turbo, jus seems like a better choice, only because i see alot of the top drag racing civic's run b18c and h22 and some b16
