I really need some help !!!!!!!!!
autox 89 dx
Member
Well I was pulling up to a stop light and the car just died towed it home and I have no fuel pressure or spark. I changed my distributor and still nothing I have no clue what it could be. I also changed my main relay and it still doesn't work what else can it be? All the fuses are good and I was wondering if it could be my ECU?
I have a SOHC ZC with a Z6 head with a Rywire harness kit running a P28. Also I checked the wires to the fuel pump and they get no juice at all I'm stumped???
Can someone please help if they have any ideas.
well if the main relay is good it will make a click sound when you turn the key on, and check the fuses under the hood and timing belt
well the main fuse is working and all the fuses are good so I'm gonna try to jump the fuel pump to see if its any good:confused:
try the starter relay the same thing happened to me on my old car
