Ok he wanted to know how long the book time for the swap is or how long total doing everything took yall. also i emailed Honda for all the vacuum diagrams and torque specs but i get bs answer saying buy the helms. I know recked said go to autozone.com but they don't have 92 specs only 95 up. I know its same generation but i dont know if there r ne small changes. If anyone has a link for a site with vacuum diagrams and etc plz let me know. Thanks
what?
autozone should have EVERYTHING prior to 95...
nothing newer...
and yea, helms are dumb money but well worth it if you own the car long term...
vac diag's should be availbale from autozone though
and what swap are you doing?
some are fast, others are more complicated...
your standard swap should take 2-5 hours depending on your skill, and then you need to tack on a few hours for wiring vtec, or handling other issues, like new mounts, etc...
motor replacement + swap specifics...
H22 swap intoa civic or integra would probably be the most time consuming, unless you were doing an 88-91 b series and needed to bend metal and weld your shifter rods...
some other things...
don't waste your time emailing honda about anything unless you want to spend money on a new car...
anything else and they will tell you to GFY, occassionally you'll find a technician at a local dealership that will talk to you about your problems and concerns...
i don't remember exactly what you needed but here's 92-95 prelude with H23 and H22 vac diag's from autozone...
http://autozone.com/servlet/UiBroker?Forwa...23d800d0656.jsp
And what kind of mechanic has to ask you 'Hey, go get on the internet and see how long it takes to swap a motor.'
lol, sounds to me like he was asking the mechanic for an estimate...
and i;m also guessing your mechanic doesn;t normally do swaps...
do you have any other mechanics you can go to?
he'll get half way through it and then you'll be back asking us questions and we'll be doing his job for him through you...
