hey guys, so i just finished my turbo install on my B16a2
i started it up today on my P06. it was already chipped and socketed and had a program running in it all of last summer that a reputable tuner wrote for me on the dyno (splitfire, for anyone in Toronto)
so today i wanted to start my car to let it idle and bleed the cooling system it idle mint, no hiccups no misfires and NO CODES. i got my usb drivers set up today for my ostrich so i go out later tonight and decide to see if it will communicate with the ECU, so i pull out my chip, and plug in the ostrich, i uploaded a stock p30 map, (my b16 is unmodified internally) so i figured that would work, then i was gonna play with idle and stuff just to see if it would respond. well it says it was, it verified the rom, i removed checksum from rom, disabled injector test and knock and ELD and started it up, it ran like a bag and the engine light stayed on solid, wouldnt shut off even with KOEO. so i trie to change some fuel and idle just to see, like i said if it would change, well the progress bar says it was sent, and it said the rom was verified. but it didnt change anything with the engine, so after disabling a bunch of stuff to see if the light would go out, it wouldnt, so i put back in my old chip and took out the ostrich, the light now stays on with my old chip and it has a solid cel. when jumping connector, no flashess just solid light, so i got a stock P05 ecu i had from a 94 CX. it idled funny, but i expected that, but the engine light didnt come on, is there anything i can do to check why i now suddenly have a solid ceL after plugging in the ostrich. this is my first attempt at playing with it, any direction anybody can send me in i would appreciate it. im new to crome and ostrich so i could have very well done something wrong, but the cel wasnt on with my old chip, so why could it possibly be on after using ostrich?? and just a small side note, i heard chips only work when put in one way but the ostrich and my 27c256 chip operated both ways.... by the way its a chipped P06 ecu tuning Via Crome Pro
and nothing on the board i can see looks burnt or fried............... thanx!
