I Think My Tranny Needs Help
Discussion in 'General Tech and Maintenance' started by hondakpariaug, Jun 25, 2005.
  1. hondakpariaug
    hondakpariaug Junior Member
    hi im new
    i need some serious help, i have a 1992 Honda Accord with an automatic tranny (no VTEC) i know that the engine has at least 140hp. i cant get my car to take off fast or even a little ok. my mom has a 2000 Honda CR-v auto with only 100hp and it can do long burnouts, but mine feels weak.
    i have 168000 miles on it what do you think i can do about.
    THANKS
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    I think your motor is shot, and accords are heavy.
    do a compression test.
  3. hondakpariaug
    i have very good compression because it was very hard to move when the timing was being set (right)
    ne other suggestions
  4. n1mr0d
    n1mr0d Senior Member
    Channahon, IL
    168k would make me think that your clutches are slippin in the auto tranny. Especially since you say u have good compression.
    Addition: Might also want to take a look at your tranny fluid level. Could also be a cause of poor shifting and loss of acceleration.
  5. hondakpariaug
    i will see what i can do about the tranny but please keep the suggestions coming they are really helpful
    THANKS
  6. B16CRX
    Greenville, SC
    being hard to turn by hand doesnt mean anything. you have to do a compression test to really know if your compression is ok. You can rent a compressiont ester from autozone and get directions on how to do it. it takes 5 minutes to perform the test. LEt us know your results :)
  7. hondakpariaug
    i didn't turn it by hand i didn't touch it im only 15 but my dad is a certified mechanic and he was having a really hard time turning it with a wrench and an iron pole on the handle he had to use a pry bar and hammer on the gear.
    but thanks for the help i will rent the tester and tell u my results ASAP
  8. hondakpariaug
