i want more power with my b18b
Discussion in 'Civic and del Sol - EG and EK' started by integra41042, Jan 25, 2010.
  1. integra41042
    integra41042 New Member
    Northern KY
    I'm thinking a valve job and a good port and polish skunk 2 intake manifold. I have a nice header sitting here. then instead of spending 2000 on a stroker kit cant i just take some b20 pistons and rods with the b18 crank or some kind of combination like that? Or just leave the bottom end alone. I had a stock ls with an itr trany in an eg turn 14.6 at 93. Im trying to just get into the 13s. can I do that with a stock lower end? Oh and by the way, I do not want to do anything with a turbo.
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    NO B20 pistons......period...who ever told you that likes-a-the-crack-a-pipe. You'd have to bore your cylinders to put OEM ones in....silly.
    JG head for LS is legendary but other companies are good too (portflow). Port/polish/cams/springs/retainers/IM/TB/Injectors/chip/tune You should get around 20-35+whp maybe even more.
    14.6 is pretty good. I did 14.78 with full interior in an EG with Full LS swap (LS trans too) with DC header...cheaper short ram and exhaust.
    13's may need a little squeeze or boost if you don't want to build the bottom (along with the top) But too much squeeze or boost and it'll go Snap Crackle Pop....Rice Crispies.
  3. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    If your wanting to go n/a --Raise compression, that is where youll get the biggest gain among other mods such as head work as explained frm ^(CAFROG)
    *if you decide to raise compression raise octane 93+, dont run 83 oct... can you say pre-ignition, just FYI
  4. integra41042
    Northern KY
    i thought a b16 18 and 20 all had the same stroke, just different. I guess i was told wrong.
  5. integra41042
    Northern KY
    i ment all the same bore, just different stroke
  6. 34diesel34
    34diesel34 Import Tuner
    USA
    B20's are 2.0 liters. B16's, and B18's are 1.6 liters. If you rebuild the bottom you might as well go with eagle rods since the engine is out of the car and tore apart. Eagle rods are stronger and can handle more abuse.:cool:
  7. pooksy64
    HOUSTON tX
    B18's are not 1.6L...;)
    average B16=
        • Displacement: 1,595 cc (97.3 cu in) 1.6 liter
        • Compression: 10.2:1
        • Bore: 81.0 mm (3.2 in)
        • Stroke: 77.4mm
        • Rod Length: 134mm
        • Rod/stroke ratio: 1.745
        • Power: 160ps (118 kW) @ 7,600rpm & 15.5kgm (152 Nm) @ 7,000rpm
    Average B18=
    • Type: 1.8 litre 16v DOHC 4 cylinder in-line
    • Displacement: 1,797 cc (109.7 cu in)
    • Compression: 11.1:1
    • Air intake diameter: 62 mm (2.4 in)
    • Bore: 81 mm (3.189 in)
    • Stroke: 87.2 mm (3.433 in)
    • Rod Length: 137.9 mm (5.429 in)
    • Rod/Stroke Ratio: 1.58
    • Power: 190 PS/140 kW @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm
    *these are average figures.. other B16's & B18's will differ such as the B18c5 (TYPE R)
  8. phunky.buddha
    Dallas / Fort Worth, TX
    No. It's in our reference section, along with a "which engine is what" guide. Go read. Short answer:
    B16A/B = 81mm bore, 77.4mm stroke
    B18A/B = 81mm bore, 89mm stroke
    B18C = 81mm bore, 87.2mm stroke
    B20B/Z = 84mm bore, 89mm stroke
    There IS a B20A with an 81mm bore and some weird long stroke, but it came in the late 80s to early 90s Prelude and is a really screwy engine to work with. You do NOT want to swap one into another car- there's practically no aftermarket support for it.
    Go read up. Learn. Then come back and ask more questions... and stop listening to whoever told you that B20 pistons would go into a B16/B18.
  9. pooksy64
    HOUSTON tX
    +1
