I want new motor cannot decide
Discussion in 'HYBRID -> ED-EF / DA' started by upgrade, Jan 11, 2009.
  1. upgrade
    upgrade New Member
    I got a 1989 Honda LX 4dr. auto. I am looking at motor swaps. Cannot make up my mind been leaning torwards the ZC or the D16A6 or D16Z6. really want Vtec though, but am wanting to get motor locally. like from usa cars and not importing. and wanting D series so no changing motor mounts and bull shit. just simple swap. Let me get some input on what to do.
  2. D16SiHatch
    D16SiHatch New Member
    d16z6 would be your best bet then. convert to obd1, run a p28, and be done with it. if you're dead set on purchasing locally you might also give craigslist a try.
  3. upgrade
    upgrade New Member
    the p28 ecu...what car did that come out of?
  4. upgrade
    upgrade New Member
  5. upgrade
    upgrade New Member
    and i have a 1989 civic lx not a si so i dont have multi port or the d16a6. that was a swap option. the D16Z6/Y8 swaps are calling for D16A6 parts and what is the difference between the PR3, PW0, or PS9. and what cars did the ecus come out of?
  6. D16SiHatch
    The p28 is from a 92-95 civic ex. its the ecu that runs the d16z6 stock.
    You could use a y8 if you so choose. some people recommend one over the other but honestly they are very similar and you won't notice any appreciable difference between the two.
    To do any kind of decent sohc vtec swap you will need to convert from dpfi to mpfi.
    http://hondaswap.com/swap-articles/dpfi-mpfi-writeup-49557/
    pr3 - from a jdm integra, runs the obd0 b16a
    pw0 - from the jdm civic/crx sir, also stock ecu for the obd0 b16a
    ps9 - its for an 88-91 civic 4-door EX with auto trans. basically identical to the pm6 88-91 Si ecu, only this one is for the auto trans equipped vehicle
  7. GlassHeadlights
    Calgary, AB
    Don't get a Y8, they spin bearings and are more expensive because they're newer.
    Z6 FTW!
  8. efhondakid
    Akron-Canton, Ohio
    :werd: Its just not the Y8 the Y7 suffers this same problem as well, the Z6 is very good motor.
  9. D16SiHatch
    yep. i was going to mention the spinning rod bearings issue but for some reason at the time i thought he was talking about just a head swap, not the entire engine lol. that being the case yea definately go with the z6.
  10. upgrade
    upgrade New Member
    thanks for the advice
  11. upgrade
    upgrade New Member
    now i was just looking at the 92-95 JDM D15B sohc VTEC what does it take to put that in the 1989 LX?
  12. GlassHeadlights
    Calgary, AB
    Its the same as a USDM D16Z6.
