=====IAB and Other sensors====
Discussion in 'HYBRID -> EG-EK / DC' started by hatchboy, Aug 17, 2005.
  1. hatchboy
    hatchboy Sleeves+boost=Love
    Oak Harbor/Battle ground,wa
    Allrite guys what up, here the situation. I have a 99 ex that used to be auto and now in manual.
    I purchased a JDM obd1 gsr swap.
    I am using the obd2 harness on the obd1 motor with obd2-1 conversion harness going to obd1 jdm p72.
    **How do i wire up the IAB's? most info iv found is for EG's etc.?
    **IAT
    I know that i will have to convert from the 3 pin plug to the 2 pin plug. I sthat correct?
    ** Do i have to do anything with the CFK or just leave it unplugged??
    **IAC Valve
    Well sense it used to be automatic it has the 3 pin plug, so im going to put on a 2 pin plug. Correct??
    ***FIT Valve (Fast idle Thermo)
    Do i have to connect this?
    EDIT:I read that that is only on auto's, so i should need it.
    ***IAB (secondary butterfly's)
    How do i wire them up,keep in mind obd1 motor,obd2 harness, obd2 to 1 conversion harness into obd1 ecu
    I heard somewhere you can unhook the evap or something and use that plug? or i could just put in an extra plug i have and just wire it to the harness correct? what wires?
    I think thats all the questions i have for now, Thanks for all your help guys, appreciate it.
    -Dan
  2. hatchboy
    bump
  3. hatchboy
    Come on guys, i preferr this site 50x's over honda-tech. I came here so i didn't have to deal with assholes, help me out.
  4. hatchboy
    quick thurs night bump
