I've been giving this a lot of thought. When I swapped in my prelude engine, the black box was busted on arrival. Most of us wire up the IAB, then run a hose from the intake manifold to the IAB. However, if the engine made more power without the black box, I can't think of any reason why Honda would add it. The secondary butterfly stays closed at low RPMs, which supposedly makes more low end power, and the solenoid opens the butterfly at higher RPMs. An engine makes less vacuum at higher speeds than lower. Does this black box store vacuum to be used to open the secondary butterfly?
Dunno.
I'm putting one back on because it is original equipment, and I believe the research teams at Honda to be smarter than I am. I just won an auction on Ebay to replace my broken one.
IAB auction
Dunno.
IAB auction
