IAB's
Discussion in 'ECU's, Electronics, and Tuning' started by reckedracing, Sep 28, 2005.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    this has a mechanical function in the intake right?
    i'm just trying to figure out exactly what it does, where it is, and why its important...
    if there's a write-up just point me to it and e-slap the shit out of me...
  2. pissedoffsol
    iuts a butterfly valve.
    it opens/closes to effectively change the length of the itnake runners.
    shoter runners are good for high end hp
    longer runners are good for low end torque.
    throw an electronic device on there, and you get the best of both worlds....
    edit- i might have the longer/shorter words messed up... i'm double checking myself...
    edit 2- verified correct
  3. reckedracing
    NY
    hmmm, perhaps i can find a pic somewhere...
    would this IAB be located between the large chamber and the actual runners?
    there appears to be a plate in between the "chamber" that the throttle body bolts to and the runners...
    and how does the butterfly alter the length...
  4. pissedoffsol
    basically you have a long path, and a short path...
    when the valve is open, it takes the long path
    when its closed, it takes the short path.
    the short path kinda "cuts the corner"
  5. reckedracing
    NY
    http://www.we-todd-did-racing.com/wetoddim...kZmQzMXk1NDE%3D
    pic
    so what does that sensor for the IAB do?
    and the thing right above it in the pic, with the vac line and the little arm with a spring...
    says the sensor is for IAB, but what does it measure? air flow?
    and i'm guessing the mechaincal part of the IAB is the thing right above the sensor?
  6. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    The sensor in that pic is the IAT. The sensor for the IAB's is connected to the vacuum cannister. It's not completely neccesary to have the vacuum cannister hooked up (I had a vacuum line running directly to the manifold), but I believe you still need the sensor connected to the vacuum cannister.
    The thing with the vac line and the spring is the actuator for the IAB.
