IAC valve
anybody know were the IAC valve on a d16z is? what colors are the wire? my car ran a CEL code 14 and said it's the IAC valve, idle thermo valve or throttle body. by the way what is the thermo valve? anything will help guys.
it has two coolant lines going to it and a 2wire plug as well.
i would say to check your idle adjustment screw also... if that has been played with too far, the throttle butterfly wont close enough and the IAC valve wont be able to correctly compensate
coolant flows through the valve fine. i'm pretty sure it's not the thermal valve. i took the IAC off the blew to a hole on the side which did not have the screen. It's pretty tight. then i took my cousins off. i blew onto it and it's smooth. i haven't switched the valve form my cousins car yet, going to do that. that peice of shit cost me 300 bucks. i'm headed to the yard, forget a new one.
