EG6D16Z6_NA
Member
okay, had an CEL on and pulled out a code 14, IAC valve. I took my cousins IAC and put it on mine. erased the memory and it's still on. the coolant lines that goes to the valve tends to be warm when you start the engine for only a couple of minutes. can it be the termo valve? I noticed my idling. At 1500 RPMs, it shrugs on me. below or higher than that is okay. what do you guys suggest?
94 D16Z6 single vtec
