The del sol is pretty much a taco. I have an extremly agressive suspenision setup, and even while autocrossing, its almost impossible for me to do the "pissing Dog" basicly, it is because the targa top. Just running with the top on really does nothing because the top actually does not take any stress. It pretty much just floats on the top, and the latches are there so that when you hit a bump, it doesn't flyup. Because of this, I am pretty scared to make a bracing system out of this. Reason is, because it is not designed to take any load, by making it take load, you could possibly put too much force on the winsheild or rear window and patentailly crack them. That really isn't an option.
1.
2.
3.
The basic part of the sol that needs stiffening up is the passenger compartment. As you can see in pic 3, the top of the sol is basicly held up by the windsheild and the weld from part 2.
In Image one, there really is no supports on the floor. There is the one horizontal support that the seat mounts to, but other then that, its pretty much not there. Now here is where my idea comes in.
I saw this thing on autoweek one time were they show how they make Starcraft vans out of normal ford Full size vans. In full size vans, there really isn't any big windows. What they do is they buy full size windowless vans, then they cut a hole for the window, then they add sheetmetal strips that is folded (looks much like the bars that hold up street signs) around the area to build up strength.
Now what I was thinking is using this same technique on the sol. Basicly add some Vertical supports verticall (front to back) in part 27 in image one. Now how would I go about doing this.
1.
2.
3.
