Idea I had.
Discussion in 'Forced Induction' started by jimboburgess, Aug 6, 2005.
  1. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    We were hanging out at the local auto parts store and someone mentions electric superchargers, I think, oh you mean crap.
    then i got the idea to use a centrifugal supercharger and electric motor with enough power to spin in sufficiently, like that of a dremel tool but scaled up.
    the throttle could be controled in such a way that according to the position of the throttle it would spin at an ideal speed to maximize performance.
    other ideas would be to use a four-stroke gasonline engine like off a lanwmower or weedwhacker. and mechanicaly control the amount of boost by using a throttle cable in addition the the one on the throttle body or have it set at a constant speed pushing constant boost.
    if someone has parts lying around give it a go. the unit would fit under a hood easily enough. It would be ridiculous to hear it if you had two engines running, one your cars and the other off a weed wacker. pulleys would help adjust to rpms.
    motor, centrifugal supercharger, belts, pulleys, piping.
    any thoughts, ideas? seen this before anywhere?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    The electric supercharger has already been done. It costs about $3000 and works on just about any engine.
    Lawnmower engine = no go. It's not going to supply enough power to generate enough boost to make additional power.
  3. jimboburgess
    nyc
    here it is with a 30cc model airplane engine.
    isn't it just a matter of getting it to spin fast enough?
  4. phunky.buddha
    Getting it to spin is one thing.... getting it to spin while pushing positive pressure against a large volume and load is another. Superchargers on a B16 can eat 20-30hp easily just to pump air- if your lawnmower engine can do that, then go for it.
  5. jimboburgess
    nyc
    I guess i underestimated exhuast pressure as far as being able to push a turbo.
    I don't have the resources to build this it is just an idea that we have been kicking around
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    I've always wondered.. What if you hooked up a gas-powered leaf blower to your intake. And had a manual gate. When you hit wide open throttle, close the gate. Its got to be worth a few HP. like at a drag strip. I'd be willing to bet that a good leaf blower could do something like 4-6 psi of boost. I've never done the math, though.
    **EDIT**
    Maybe take it a step further, make it a closed system and link the throttle of the blower to the throttle of the car. Could it be a red neck super charger?
  7. phunky.buddha
    Leaf blowers move volume, not pressure. You wouldn't be able to pressurize your intake any appreciable amount with a leaf blower.
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    What If I hooked up 13 of the bastards, mythbusters style??
    :ph34r:
  9. phunky.buddha
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    Party Pooper... <_<
  11. reckedracing
    reckedracing TTIWWOP VIP
    NY
    lol, i've contemplated these things at one time but came to the conclusion none of it will work...
    the electric supercharger has definately been done, using a mercedes blower i think... the one i saw ran about 5K
    you need to think of it like this...
    your motor has a capacity of 1.6 liters for example...
    at a 1K rpm idle that 1.6 liter is sucking in 1600 cubic liters of air per minute...
    that would equate to 8000 cubic liters of air at 5K rpm
    and 13120 cubic liters of air at 8200 rpm
    so idle is 56.5 cfm
    5K = 282.5 cfm
    and 8200 = 463 cfm
    so you would need a blower or compressor that could supply a pressurized amount of air in addition to the cfm that the motor can suck in on its own naturally aspirated...
    all numbers are theoretical and should only be used as an example...
  12. jimboburgess
    nyc
    If the correct motor is used i still believe that this is possible. the only choice for the correct motor might be electric and then it has already been done.
    as far as the leaf blower i think it could push minimal boost(1-2psi), or at least eliminate vacuum. Volume in a limited area is pressurized.
  13. blackice90HB
    blackice90HB Senior Member
    Pensacola, Florida
    i know a boy with a 92 Sentra 1.6 that routed a hose from his A/?c through a hole in his fire wall to the intake box (only mods are k&n filter and slightly gutted cat.). he says he notices a significant increase, but i aint been in it yet to se for my self.
  14. GSRCRXsi
    MD
    mike, did you not see the vid of the guy who put a leafblower right up to his intake? he made 10 more whp, lol.
  15. phunky.buddha
    No, the video wouldn't work for me.
  16. Cashizslick
    Oldschool hotrod trick
  17. tab
    tab Super Moderator
    Aberdeen, Washington State
    You want ghetto?
    put a wheel to the ground and let the speed of the car push the supercharger. The faster you go, the more boost you get. :ph34r:
  18. phyregod
    phyregod !!YTINASNI
    Central Texas
    I'm now curious what kind of boost 13 leafblowers would make.....
    I'm going to write mythbusters.
  19. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    13 leafblowers wouldn't make any "boost"
    the wheel inside a leaf blow works like a fan, there is no volute, no turbine, therefore there can't be any compressed air
    however, it stands to reason that if you can accelerate the air into the intake manifold, you'll allow a bit more to find it's way into the cylinder each time the valve opens. Since the air isn't pressurized, you'd never see huge power gains, but adding velocity via a leaf blower is just as good as increasing intake velocity with another method
  20. phyregod
    phyregod !!YTINASNI
    Central Texas
    Dude, they just made 10 hp on a dyno with a single leaf blower.
    And there is a turbine, a leaf blower works on EXACTLY the same principles that a turbocharger works.
    I'm going to have to do this, so everyone will STFU.
