With what turbo? What power goal?
About 300-350whp, depending on traction, for a 2500lbs. chassis.
You'll probably want around 9:1 to 9.5:1 if it's a street car.
Careful with that "built" ITR head. If it has all motor cams in it you will have some overlap. This is undesirable in any forced induction application.
Any cam that has a high duration and a lot of valve over-lap. Turbo cam profiles usually have higher lift and a shorter duration for less over-lap. Valve over-lap means that you're blowing boost out of the exhaust ports.
So thats pretty much useless boost then?
It has JDM GSR Cams.. What cams are you talking about exactly as in all motor?
