Ideal Engine Management System?
Discussion in 'Engine Building' started by Ozwald, Nov 6, 2013.
  1. Ozwald
    Ozwald Member
    New York
    So, just wanna bounce some ideas off of the general public about what they feel would be the perfect engine management system. This includes sensors and actuators.
    My senior project (next year) for my electronic major is to build a computer and program it. So i though, why not make a ecu that is a little more versatile than money can buy. It will be implemented on my B20
    Here is my list so far for sensors:
    O2 sensors per cylinder
    Intake air temp
    Manifold absolute pressure
    throttle position sensor
    Knock sensor
    Coolant temp
    oil pressure
    crank speed sensor
    cam position sensor
    For the outputs
    fuel injectors
    coil over plugs
    idle air control
    v-tec (i have the b18 head on)
    If you have any other sensors or things that need to be controlled feel free to add.
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    Wow, good luck. Don't forget about all the interior crap too though.
  3. Briansol
    you're about 75 sensors short of passing emissions :)
  4. Ozwald
    Ozwald Member
    New York
    emissions is not a concern with a track car :D
    For right now all the interior will just be read outs on the my computer ill integrate it later
  5. reikoshea
    Dallas, TX
    Vehicle Speed Sensor?
    Radiator Fan
    That's all I got.
  6. Briansol
    I think you're in way over your head and while it sounds cool, I don't think you full understand the scope of your own project. It's not about hooking up some sensors and writing a switch statement for case(sensor){}... getting a motor to just run is a delicate balance of reading, interpreting, and real-time adjusting. the AI and algorithms involved are well above and beyond electrical work... it's hard code machine binary and hexadecimal coding with C. Do you even know C?
    If you make a mistake, the car won't run.
    Or worse, it blows up.
    There's software like crome that had easily 5000 man hours into developing. And that used the STOCK Honda computer to interface with.
    I appreciate your ambition, but if it comes to demo day and your car blew up and doesn't run, you'll still get an F even if you spent your whole year on it.
    Scale back and attempt something that actually can be done in a reasonable time frame that doesn't have outside factors like blowing up your multi-thousand dollar motor.
    blow up a $5 radio shack board instead.
