Idle <500RPM...
eml1618
Member
B16A2, stock jdm civic OBD2 ecu...idle seems somewhat low just under 500 at most...it fluctuates between about 200 and just under 500...seem low or is it just my nit picking ass <_< ?
2-500 rpms is low, I don't know your specs, but I'm sure you should be between 5-800 somewhere.
You'll need a manual to adjust the idle, IF there is no underlying cause to your low idle.
I don't believe there would be anything wrong, the only thing i could think of was something with the grounds or ignition...
check your air filter, it could be super dirty. If that fine, you may have to adjust your idle screw.
