idle air control valve issue.
Discussion in 'General Tech and Maintenance' started by Warrior 3000, Mar 25, 2009.
  1. Warrior 3000
    Warrior 3000 New Member
    my car was changed form an auto to a 5 speed and the idle air control valve was taken out. my car cant even pass inspection without one. how much does it cost to get this thing put in?
  2. MthaFuknGreen
    Lodi, CA
    why the fuck would they take that out?
    its not necessary for an auto to manual swap, and itll just make youre car run shitty..
    are you sure thats what you need?
  3. Warrior 3000
    "it runs perfect the car its self has no idea that its been changed, it doesnt need a new harness the iac valve needs to be replaced and rewired, if u can get some to pass it with the tranny code you will be fine that how I have had it for the last 9 years or so"
    "the code that the car has now in NO way hurts the car because the car was changed from auto to stick without changing the ecu, the ecu looks for the auto tranny and cant find it so it throws the code
    The iac valve in the car is not the right one for the stick ecu, it is the correct one for the auto ecu (which is the one in the car now). A stick civic has a two wire iac valve the auto has a 3 wire iac valve so the stick ecu cant read it thats what the code is."
  4. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    there is a diffrence between the Auto and Standard IAC, and you are looking to spend about $140 for the unit but i dont know about the wiring harness
  5. Matts96HB
    Matts96HB . Moderator VIP
    Run your own wires and pick one up from a junkyard. Probably about $50-$60 and you're done.
  6. MthaFuknGreen
    Lodi, CA
    are you sure youre talking about the Iacv? not the Eacv?
    cuz theres no wires on the idle air control valve.
    there is on the electronic air control valve.
    and whats with the quotes?
  7. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    eacv/iacv it's the same thing. my b16's is called an iacv and it has a linear 2 wire valve. then there's 3 wire resistive type (i think it's called).
    summery: buy a Helms, Haynes, or Chilton manual from your local auto store!
  8. MthaFuknGreen
    Lodi, CA
    oh yes yes.. im thinking of the fitv.
    lol
    i deal with intake problems too much. haha
