Idle increases when i turn on my lights
Discussion in 'General Tech and Maintenance' started by 95preludetypes, Nov 17, 2004.
  1. 95preludetypes
    95preludetypes Member
    When i turn the headlights on in my 95 prelude the idle increases by almost 300 rpms. dose this have something to do with the alternator thanks for your help.
  2. preludebuddy
    preludebuddy Senior Member
    putting the rad in colorado
    my 94 type s did that too, i just ignored it. i eventually ran into the problem of my lights shutting on and off while driving, which sucked. it turned out to be one of the wire connectors, but it got fried twice before my lights started working again.
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    get you alt tested and check all the connections on the battery aswell
  4. brian11to1
    brian11to1 Senior Member
    How much does it increase? A minimal amount you should worry about, as the lights draw current from the Alternator and cuase the engine to rev higher (like 50RPM's) to accomodate the load of the lights. Just an idea, but I wouldnt worry about anything.
  5. nfn15037
    nfn15037 Senior Member
    The RPMs rise because of the electrical load detector. The ECU knows when there is increased electrical load on the alternator, and signals the IACV to react accordingly. It just overreacts sometimes.
