Idle Issues after New thermostat install..
Discussion in 'HYBRID -> BA-BB /CA-CD' started by DhN, Dec 24, 2005.
  1. DhN
    DhN Junior Member
    so i installed my new thermostat..drained bled and filled system with coolant and everything..now i get a very low idle...like...2-100 ish...after car is warmed up of course...im also getting the egr and knock sensor codes even after resetting my ecu like 3 times after this whole shabang [​IMG] ....anyone know whats going on?
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    maybe your harness is all wet? Did something get pulled out on accident?
  3. DhN
    DhN Junior Member
    nah..im also shooting 2 codes..knock sensor and egr..but i think its cuz of my p13....cuz i dont have the egr blocke doff or anyting..the car runs fine..but after whikle..the idle gets real low
  4. reikoshea
    Dallas, TX
    welcome to my world. Im gonna replace my EGR since i have a Dec 91 Motor. Im gonna see if it helps. My car runs, but glugs when the CEL is on. I have the exact same problem. I dont know if im gonna do it with this paycheck, but we will see. Ill let you know how it turns out if i do it next week.
  5. tab
    tab Super Moderator
    Come to think of it, my buddy's Accord did the same thing when his car warmed up. The car would idle fine warm, then bam, it wouldn't even idle. It would die at intersections if your foot was not on the gas. His car didn't throw a code. His EGR itself was fine, but blockage of the passageways didn't let the valve do it's job. Try disconnecting the EGR vacuum reference(and block the hose). See if your car idles better.
  6. reikoshea
    Dallas, TX
    It does idle better, but i still have no power at WOT
    I figured the lack of an EGR was throwing my AFRs off and i also thought it could be the high combustion temp causing a knock.
  7. tab
    tab Super Moderator
    Do you have VTEC with the EGR code?
  8. reikoshea
    Dallas, TX
    i do, but its weak since i cant go WOT.
